5 Signs You've Outgrown Zapier
Is moving from Zapier to Workato right for you?
Trusted by Over 21,000 Organizations
Workato is lightyears beyond other products I have used in the past. It is much easier to use and very intuitive. It's also architected for the modern ecosystem of API-based applications.
Aaron Yee
Sr. Technical Marketing Manager
Okta
Workato has blown me away. What I was able to do in a couple of hours would have taken months of custom development work if we had taken that on ourselves.
Drew Parker
Business Systems Engineer
Box
Contact: (844) 469-6752
© Workato 2018
Privacy Policy
"Workato is Zapier on Steroids. It is a perfect blend between a simple out of the box connection with Zapier, and hiring a developer to create a custom integration. It can create complex integrations without the expense of a custom developer."
JONATHAN QUINN,
Construction Labor Services of New England
I WANT TO READ THIS
Yes! I Want this Free eBook!
Advanced Problem Solving without Coding
Workato ensures you don't miss or lose any data. Use the unique "Time Machine" for historical data sync, bulk & batch operations for data migration or initial load; capture all data- new and updated; import data from files or export to files. No matter how complex your processes, you can easily do it with Workato.
Enterprise-Grade Security and Control
Enforce policies to control access for creating, changing and operating recipes. Easily monitor and audit activity, access and changes. SAML-based SSO or LDAP integration to centralize controls authorization to all accounts & applications.
The platform provides data security with end-to-end encryption and data privacy with data masking.
Zapier | ||
Advanced Syncing Problems |
Can it move/sync existing data? | ||
Can it guarantee zero data loss? | ||
Can it sync changed/updated items to keep data in sync? | ||
Can you use it for importing and exporting large volumes of data? | ||
Can it support batch operations for high throughput? | ||
Can it support bulk triggers, custom queries (e.g. SOQL)? |
Workato is a perfect blend between a simple out of the box connection with Zapier and hiring a developer to create a custom integration. It can create complex integrations without the expense of a custom developer."
Jon Q
on
“First off, your solution is awesome and I'm so glad I gave it a shot. It blows Zapier away.”
Eric Prugh
Essential Connectivity and Critical Operation Support
Connect to core enterprise apps for HR (Workday), Finance (Netsuite), ERPs (SAP, Oracle E-Business Suite), and databases (e.g. Oracle) for truly mission-critical automation.
Build advanced automation using the power of branching (IF-THEN), aggregation, merging and routing operations, 225K+ community recipes, callable recipes, lookup tables and more to quickly automate complex business processes.
Zapier | ||
Enterprise Level Security |
Does it give you control to keep your sensitive customer and business data safe? | ||
Can you enforce policies for access control to limit what each role can view, create, change and operate? | ||
Can your company meet the industry standard compliance and security to protect internal and customer data? | ||
Can you monitor and create reports to track consumption, change impact, dependencies and audit activity/access/changes? |
Zapier | ||
Reliable Enterpise Connectivity |
Can it connect database apps and ERPs used by your company? | ||
Can it connect to mission critical HR , IT, Finance apps e.g. Workday, ServiceNow? | ||
Can you securely connect to apps in your corporate data center e.g. databases, ERP without opening up the firewall? | ||
Can it support advanced logical operations - IF-THEN/branching, aggregation, merging, routing - that your business processes need? | ||
Can it process advanced data types - arrays, nested data structures; parse, create or move documents, media files, attachments? |
Workato Covers Every Part of Your Mission Critical Automation
