About the Lesson
Just because you are not writing code, doesn't mean it is not software. Even though you built your recipe for your specific use-case, it is still valuable software that can be re-used, re-purposed and possibly updated by others (in your team or in our community). Therefore, it is important to ensure you add enough comments in the recipe and manage versions so you do not lose any work and make collaboration easier.
Creating good recipe-building habits is essential to building good recipes. Learn about the Workato tools that give you the ability to quickly add documentation for the recipe, work with versions of the recipe and re-use/share.
Documentation, Re-Use, Share, Versioning
Key Learning Points
Key Learning Points
Jumpstart your journey to being an automation expert in 5 days.
LESSON 5
Foundations for the Future
