Your business requires a wide range of apps to function. You need to be able to have your sales, HR, IT, and finance teams all work together. Combined you can create automation that works across your entire company.
Workato is designed exactly for enterprise customers looking for a robust, and powerful solution. Workato helps you connect core enterprise apps for truly mission-critical automation.
Trusted by Over 21,000 Organizations
Workato is lightyears beyond other products I have used in the past. It is much easier to use and very intuitive. It's also architected for the modern ecosystem of API-based applications.
Aaron Yee
Sr. Technical Marketing Manager
Okta
Workato has blown me away. What I was able to do in a couple of hours would have taken months of custom development work if we had taken that on ourselves.
Drew Parker
Business Systems Engineer
Box
Contact: (844) 469-6752
© Workato 2018
Privacy Policy
Advanced Problem Solving without Coding
Workato ensures you don't miss or lose any data. Use the unique "Time Machine" for historical data sync, bulk & batch operations for data migration or initial load; capture all data- new and updated; import data from files or export to files. No matter how complex your processes, you can easily do it with Workato.
Enterprise-Grade Security and Control
Enforce policies to control access for creating, changing and operating recipes. Easily monitor and audit activity, access and changes. SAML-based SSO or LDAP integration to centralize controls authorization to all accounts & applications.
The platform provides data security with end-to-end encryption and data privacy with data masking.
Zapier | ||
Advanced Syncing Problems |
Can it move/sync existing data? | ||
Can it guarantee zero data loss? | ||
Can it sync changed/updated items to keep data in sync? | ||
Can you use it for importing and exporting large volumes of data? | ||
Can it support batch operations for high throughput? | ||
Can it support bulk triggers, custom queries (e.g. SOQL)? |
Workato is a perfect blend between a simple out of the box connection with Zapier and hiring a developer to create a custom integration. It can create complex integrations without the expense of a custom developer.
Jon Q
on
“First off, your solution is awesome and I'm so glad I gave it a shot. It blows Zapier away.”
Eric Prugh
Essential Connectivity and Critical Operation Support
Connect to core enterprise apps for HR (Workday), Finance (Netsuite), ERPs (SAP, Oracle E-Business Suite), and databases (e.g. Oracle) for truly mission-critical automation.
Build advanced automation using the power of branching (IF-THEN), aggregation, merging and routing operations, 225K+ community recipes, callable recipes, lookup tables and more to quickly automate complex business processes.
Zapier | ||
Enterprise Level Security |
Does it give you control to keep your sensitive customer and business data safe? | ||
Can you enforce policies for access control to limit what each role can view, create, change and operate? | ||
Can your company meet the industry standard compliance and security to protect internal and customer data? | ||
Can you monitor and create reports to track consumption, change impact, dependencies and audit activity/access/changes? |
Zapier | ||
Reliable Enterpise Connectivity |
Can it connect database apps and ERPs used by your company? | ||
Can it connect to mission critical HR , IT, Finance apps e.g. Workday, ServiceNow? | ||
Can you securely connect to apps in your corporate data center e.g. databases, ERP without opening up the firewall? | ||
Can it support advanced logical operations - IF-THEN/branching, aggregation, merging, routing - that your business processes need? | ||
Can it process advanced data types - arrays, nested data structures; parse, create or move documents, media files, attachments? |
Your Business Doesn’t Move in a Straight Line. Neither Should Your Integrations.
“When I share my integrations at panels or tell other administrators about Workato, everyone is floored by how easily you can integrate without code.”
Cheryl Feldman
Salesforce MVP/Admin
Namely
